NA8C HundredOne
Napsal: 26 úno 2010, 18:16
od Lobo
few pics..
Tsukuba Circuit 2000
1:00.307 2004 REV Super Battle Official Records
info a specs: http://www.hundred-one.com/demo1.htm
eng:
Engine
Maximum Output: 320PS (315hp) @ 8500 RPM :D :D
Maximum torque: 35Kg (253 ft-lb) @ 6,700 RPM :D :D
Built by: Maruha Motors
Displacement: 1930cc
Bore × stroke: 85.0mm × 85.0mm
Compression ratio: 12.7: 1
Intake system: TOYOTA 4AG individual throttles
ECU: MoTeC M48-ADV ROG
Ignition coil: MoTeC
CDI: MoTeC
Cam: Toda Racing 300 degree 10.7mm lift
Lifter: Toda Racing shim under bucket solid mechanical type
Valve spring: Toda Racing strengthened type
Timing gear: Toda Racing adjustable
Piston: Toda Racing forged 85.0mm φ
Connecting rod: Crower
Crank: Original crank lightened and polished
Head Gasket: Toda Racing 0.8 mm
Oil cooler radiator
Nitrous oxide: Dry shot × 8
Drivetrain
Clutch: ATS carbon clutch
Transmission: MATSUDA SUPIDO FURUKUROSUMISSHON (???)
LSD: ATS carbon LSD
Final Drive Ratio: 5.1:1
Suspension
Shock absorber: OHLINS MH-P
Spring: Swift F 13Kg R 11Kg
Control arms: Manatee Racing adjustable
Uprights: SP-TEC
Tire/Wheel
Wheel: Panasport F: 15X8J R: 15X8.5J
Tire: Yokohama A048 F: 225/50-15 R: 225/50-15
Brake
Brake rotor: For NA8
Brake pads: F: ED CC-M R: ED CC-M
Body
Body reinforcement: Increase spot welds + roll cage
Front spoiler: Garage Hundred One wide body
Hood: Garage Vary lightweight type
Door: FRP lightweight
Hard Top: Garage Vary lightweight type
Over Fender: NOPRO
ke dnesnimu dni prekopano na 2,1 :)
Napsal: 26 úno 2010, 20:36
od riderhenry
dobrej seznam, to bych mohl pouzit jako dopis jeziskovi... :D
Napsal: 26 úno 2010, 22:15
od infinity
mhh...hodne pekny...Predpokladam avizovanych 320ps je behem NOS shotu :)
Napsal: 27 úno 2010, 10:20
od Georgee
sakra, to jsem mìl pøipravený na blog :lol: tak sem alespoò pøidám video :D
http://www.youtube.com/watch?v=mmvd63Nt1jg
Napsal: 01 bře 2010, 15:22
od Lobo
infinity píše:mhh...hodne pekny...Predpokladam avizovanych 320ps je behem NOS shotu :)
jojo s nos...
stavajici setup ma tuhle podobu :)
Power:
* Engine: BP
* Pistons: Marri(?)
* Rod: Maruha
* Crank: Maruha
* ITB: JENBI/ Maruha
* Overbore: 2040CC
* Radiator: Tabata
* Ex. manifold: Maruha
* Engine Cover: Maruha
* ECU: Motec
* Muffler: GHO One Off Titanium
* Sequential Transmission
* Estimated HP: 218
Handling/ wheels:
* Ohlins MH,
* Swift Springs 13Kg Front, 11Kg rear
* Manatee Control Arms
* Weds: 15x8.5 +5 offset
* Advan A048
Exterior/ Interior:
* GHO Original Front Bumper
* GHO Original Hood
* Nopro Flares
* GHO one-off Trunk
* GHO one-off Rear Garnish
* GHO Original Mirrors
* Stripped interior
* GHO one-off Carbon Fiber Dashboard
* Motec Dash Loger
* Weight (Tsukuba TT: 836 Kg), Maximum Possible: 796Kg
Napsal: 01 bře 2010, 18:30
od riderhenry
tak tech 218 kobyl je tak idealni na to moje denni jezdeni :D
